Apr 23rd, 2024, 1:03am
"No connection module found" error in a Verilog-AMS code of a PFD (Read 95 times)
polyam
Oct 28th, 2017, 4:47pm
I am using the following Verilog AMS code as a Phase Frequency Detector(PFD) and the symbol has been correctly created.
//Verilog-AMS HDL
`include "constants.vams"
`include "disciplines.vams"
`timescale 10ps/1ps
module PFD (up,dn,fref,fdiv);
input   fref;
input   fdiv;
output  up,dn;
wire fv_rst , fr_rst;
wire reset;
reg q0,q1;
assign fr_rst=reset | (q0&q1);
assign fv_rst=reset | (q0&q1);
assign reset=fref & fdiv;
always @ (posedge fdiv or posedge fv_rst) begin
if (fv_rst) q0<=0 ; else q0<=1;
always @ (posedge fref or posedge fr_rst) begin
if (fr_rst) q1<=0 ; else q1<=1;
assign up=q1;
assign dn=q0;
I also created a test bench along with a Config view (Use Template --> Name: AMS).
In the ADE L, I switched to ams as a simulator.
Running the simulation gives me the following error:
Successfully compiled ('PLL' 'PFD_TB' 'schematic').
Compilation successful.
ncelab: *W,AMSNEWSFE: You have set the environment variable AMS_NEW_SFE. This is no longer needed as IUS 9.2 and above only works in new SFE mode.
     Elaborating the design hierarchy:
ncelab: *N,SFEDPL: Deploying new SFE in analog engine.
     Discipline resolution Pass...
net5 ), .dn( DN ), .up( UP ), .fref( net6 ) );
ncelab: *E,CUVNCM (./ihnl/PLL/PFD_TB/schematic/verilog.vams,20|3): No connection module found:Need an input port of continuous discipline electrical, and an output port of discrete discipline logic, at instance PFD_TB.I7.
ncelab: *E,CUVNCM (./ihnl/PLL/PFD_TB/schematic/verilog.vams,20|40): No connection module found:Need an input port of continuous discipline electrical, and an output port of discrete discipline logic, at instance PFD_TB.I7.
Failed to elaborate ("PLL" "PFD_TB" "config").
I do appreciate any help  :).
Tnx
polyam
Re: "No connection module found" error in a Verilog-AMS code of a PFD
Reply #1 - Nov 2nd, 2017, 8:09am
Problem solved!
To deal with this problem just include Affirma AMS connection module libraries.
polyam
Reply #2 - Nov 2nd, 2017, 8:11am
These libraries can be found in the following path
Cadencinstalldirectory/tools/inca
or
