Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Apr 18
th
, 2024, 6:44pm
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› Simulation of voltage doubler
Previous topic
Next topic
Simulation of voltage doubler (Read 2255 times)
rhonny90
Jan 04
th
, 2018, 12:06pm
I want to design a voltage doubler(Using Dickson charge pump with 2 clocks) with
input voltage=Vdd=3.3V
output voltage=approximately =>6 volts
Frequency=1MHz
capacitance=5pF
I took period of clock as 2 us and width as 1 us.(zero value=3.3V and one calue=0 v)
I want the Mosfet's in saturation but they are either in region 0 or 3.Please help me out in working this circuit.
IP Logged
kumar.g
Frankfurt, Germany
Re: Simulation of voltage doubler
Reply #1 -
Jan 5
th
, 2018, 1:35am
Please be more specific. Which MOSFETs are you referring to?
IP Logged
rhonny90
Reply #2 -
Jan 5
th
, 2018, 2:25am
all of them are not in saturation
IP Logged
Jacki
Reply #3 -
Mar 26
th
, 2018, 5:47am
Why do you want your transistors in saturation region (2)? In a charge pump, the transistors are only switches, they should be either on or off.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
