Apr 19th, 2024, 9:06pm
Wrong behavior of dcblock and dcfeed in Cadence Spectre (Read 2588 times)
cheap_salary
Feb 16th, 2018, 1:45am
"dcblock" and "dcfeed" are very common in RF simulator such as Keysight ADS and Keysight Goldengate.
They are available even in Cadence Spectre after version 14 or 11.
"dcblock" has to be "perfect short" except for DC and Tran Analyses.
"dcfeed" has to be "perfect open" except for DC and Tran Analyses.
These are implemented correctly for AC and PSS Analyses of Cadence Spectre.
But they are wrong for PAC Analysis of Cadence Spectre.
"dcblock" is treated as "open" for sideband=0 in PAC Analysis.
"dcfeed" is treated as "short" for sideband=0 in PAC Analysis.
These are wrong.
These are true for all slave small signal analyses subjected to master large signal analyses.
Behavior of "dcblock" and "dcfeed" are completely wrong in PAC, PXF, PNoise, PSP, PSTB, QPAC, QPXF, QPNoise, QPSP, HBAC, HBXF, HBNoise and HBSP.
My Spectre's Version is "17.1.0.124".
« Last Edit: Feb 16th, 2018, 9:30am by cheap_salary »
Re: Wrong behavior of dcblock and dcfeed in Cadence Spectre
Reply #1 - Feb 18th, 2018, 12:35am
I tried this (in 16.1.0.567.isr12 and 17.1.0.160.isr2) and I see what you're seeing. I used this circuit:
V1 (in1 0) vsource type=sine freq=1M ampl=1 pacmag=1 dc=0.5
Iblock (in1 opblock) dcblock
Ifeed (in1 opfeed) dcfeed
R1 (opblock 0) resistor r=1k
R2 (opfeed 0) resistor r=1k
pss pss fund=1M harmonicbalance=yes harms=5
pac pac start=1k stop=100k
The opblock and opfeed responses appear to be the wrong way around for the pac analysis results.
This won't get fixed by stating it in this forum - please report it to Cadence Support.
Andrew
Frank Wiedmann
Munich, Germany
Reply #2 - Feb 19th, 2018, 2:37am
By the way, all of this only applies to harmonic balance (like in Andrew's example); these components are explicitly not supported for shooting pss (see the manual at https://support.cadence.com/apex/techpubDocViewerPage?path=spectreRF/spectreRF16...). I don't really understand why, as they should be able to use the same behavior as for a tran analysis. A corresponding enhancement request (CCR 1089307) that I filed more than 5 years ago is still in "Inactive" state.
Reply #3 - Feb 19th, 2018, 3:50am
Hi Frank,
I agree, it would be sensible to just implement them as large inductors or capacitors as with transient. I think it's just a matter of priorities meaning that more urgent things got done instead. The CCR filed on your behalf was filed with a low severity because the workaround is of course just to use a large inductor or capacitor; really the only point of using dcblock/dcfeed is if you're going to be using harmonic  balance. If you're not going to use hb, then there's not that much benefit in using them in the first place.
Andrew
