abhilash_172
india
Hi @ Geoffrey_Coram, i am simulating a D flop using transistors not the verilog code.
1 . in the waveform picture i posted output is coming for sometime, then there is solution error. 2 . tried increasing the cmin value in spectre options, Now its working fine, but if i run it for really long time again the same issue " zero diagonal found in jacobian".
