Dec 14th, 2025, 9:46am
How to model strength using WREAL  ? (Read 2059 times)
Ravi Shekhda
Mar 01st, 2018, 8:56pm
    I have tried strength modelling (strong1/strong0/weak1/weak0...) in Verilog-D.
     But, Can you suggest me, How to model strength using wreal in Verilog-AMS ?
     I have tried below model....
 assign (strong1 , strong0) #2 pad_int     =   ( pu_strng === 1'b0 && pd_strng === 1'b0 ) ? `VDDA :
        ( pu_strng === 1'b1 && pd_strng === 1'b1 ) ? `VSSA :
        ( pu_strng === 1'b0 && pd_strng === 1'b1 ) ? (`VDDA/2) : `wrealZState ;
assign (weak1 , weak0) #5 pad_int =  ( pu_weak === 1'b0 && pd_weak === 1'b0 ) ? `VDDA :
                                                         ( pu_weak === 1'b1 && pd_weak === 1'b1 ) ? `VSSA :
                                                         ( pu_weak === 1'b0 && pd_weak === 1'b1 ) ? (`VDDA/2) : `wrealZState ;
While simulation of above design, I am not getting any syntax error. But, not getting expected  output.
i.e.
   In case of pu_strng = 0 and pd_weak=1 ====> Output getting X
   In case of pd_strng = 1 and pu_weak=0 ====> Output getting X
-Ravi Shekhda
