Apr 25th, 2024, 1:39pm
phase noise to jitter conversion (Read 1560 times)
Vinodhini
Mar 21st, 2018, 8:52pm
Hi, I am referring to a thesis from niknejad's group, which uses the following formulae to convert phase noise to frequency uncertainity
[img][/img]
I tried calculating frequency uncertainty for the same example that was stated in the image. But I could not get the 0.1 ppm answer that he gets. can someone help me with the intermediate steps
kumar.g
Frankfurt, Germany
Re: phase noise to jitter conversion
Reply #1 - Apr 23rd, 2018, 5:38am
The equation uses a noise PSD. What is given is its value at 1M offset alone.  To calculate the integrated jitter upto 100us you would have to integrate the weighted phase noise from 5G to 10K offset frequencies. I am not sure if you have this information contained in the rest of the reference text.
Regarding the 0.1ppm, he means an accumulated jitter of 10ps per 100us time window.
View Profile kumar.g write2rammy   IP Logged
