Apr 23rd, 2024, 7:45am
VerilogA - Pulse generator with reset (Read 1872 times)
Jacob E. F. Overgaard
May 04th, 2018, 10:51am
Hello everyone.
I have been looking a little on various websites and on Designer's  Guide, but I remain unable to figure out how I deal with this issue.
I am making a set/reset pulse based on an incomming clocked signal (200 kHz at 50% duty cycle). I want to make a give set pulse (pulse width 15 ns) on rising edge and a corresponding reset pulse (pulse width 15 ns) on falling edge.
But I also want a disable input pin, that keeps set low and asserts reset.
My current implementation is shown below, and the basic behaviour works quite well. But I have remained unable to assert reset during disable = high.
Do you guys have any ideas as to how I manage this? Using @cross() in if statements doesn't work naturally, and using if statements in @cross() only checks during a transition.
// VerilogA for set/reset pulse-generator with external reset
`include "constants.vams"
`include "disciplines.vams"
module s144029_SET_RST(Clkin, Disable, RST, SET, Vdd, Vss);
input Clkin, Disable, Vdd, Vss;
output SET, RST;
electrical Clkin, Disable, SET, RST, Vdd, Vss;
parameter real pulsewidth = 15n;
parameter real tt = 10n;
real v_set, v_rst, tend;
analog begin
	@(cross(V(Clkin) - 2.5, +1)) begin
		v_set = V(Vdd);
		tend = $abstime + pulsewidth;
	@(timer(tend)) v_set = V(Vss);
	V(SET) <+ transition(v_set, 0, tt);
	@(cross(V(Clkin) - 2.5, -1)) begin
		v_rst = V(Vdd);
	@(timer(tend)) v_rst = V(Vss);
	V(RST) <+ transition(v_rst, 0, tt);
I hope my question is clear, otherwise I'd love to elaborate.
Best regards Jacob
Re: VerilogA - Pulse generator with reset
Reply #1 - May 4th, 2018, 8:58pm
Jacob,
   One thing that seems strange to me is your use of tend. Specifically, if you have one tend variable, like you do, then it seems like you should have one timer block that resets both ouputs. Otherwise it seems like you should have two tend variables, one for each output.
Concerning your question about how to implement disable, I recommend that put a conditional around the statements that assign to v_set and v_rst. Something like this ...
    if (V(disable) < 2.5)
	  v_set = V(Vdd);
    else
	  v_set = V(Vss);
Or perhaps ...
    v_set = V(disable) < 2.5 ? V(Vdd) : V(Vss);
Reply #2 - May 4th, 2018, 11:50pm
Hi Ken, thank you very much for your reply.
I do see what you mean with my variable tend, I didn't even think about it. Somehow it works as intended though, I am pretty amazed by that!
Regarding your suggestion for the implementatioon. I have tried that specific method, but the issue is it only asserts reset/set on edges and not at all times when disable is high.
One could imagine at gate level that the last gate on reset is an or-gate with two inputs. Where one of the inputs is some conditional logic that ensures the given pulsewidth, and the other input would simply just be Disable.
This way whenever Disable is high reset is asserted for all eternity.
Did this make sense?
Best regards Jacob
Reply #3 - May 5th, 2018, 12:00pm
In addition to what I have suggested so far. also get rid of the @timer blocks and replace with the following:
@(timer(tend) or cross(V(disable) - 2.5, +1)) begin
    v_set = V(Vss);
    v_rst = V(Vss);
Reply #4 - May 5th, 2018, 12:15pm
Ah fantastic Ken, thank you very much.
I will try this shortly. Smiley
Boy does VerilogA contain so many new aspects...
Reply #5 - May 5th, 2018, 1:52pm
Okay, so I did find a solution to my explained issue above. Largely based on the helpful input of Ken.
Solution:
output SET, RST;
real v_set, v_rst, tendset, tendrst;
	analog begin
			if (V(Disable) < 2.5)
				v_set = V(Vdd);
    		else
				v_set = V(Vss);
			tendset = $abstime + pulsewidth;
			v_rst = V(Vdd);
			tendrst = $abstime + pulsewidth;
		@(timer(tendset)) v_set = V(Vss);
		@(timer(tendrst)) v_rst = V(Vss);
		if (V(Disable) > 2.5) v_rst = V(Vdd);
		@(cross(V(Disable) - 2.5, -1))
			v_rst = V(Vss);
