Apr 19th, 2024, 9:42am
Spectre convergence issues device loading failed (Read 4041 times)
SureshCh
India
May 29th, 2018, 10:59am
Need advise or info on the following two issues:
1) While debugging a large circuit for convergence issues, following warning came up: I ran simulation with "spectre +aps +diagnose netlist.scs".
Warning from spectre at time = 4.02112 us during transient analysis `tran'.
   WARNING (SPECTRE-16941): Floating point exception encountered in device loading. This might result in convergence problems during simulation. Check the device model equations for any illegal operations, such as divide by 0 or data overflow.
What device is this warning related to? How to identify.
My circuit has devices with verilog A models. Is there any relation to verilog A models with this warning.
2) tran: time = 5.621 us    (5.62 %), step = 308.3 fs  (limiting signal: I0.I_QP_0.I31.I3.I9.I0.TPCK:gmnode = 7.43315 mV 7.42195 mV 7.5713 mV, stepid = 7119)
       convergence failure at residue: I0.I_QPUMP_0.I7.TP2:gmnode (RESIDUE=161.798 uA REF=7.56877 mA)
What do the 3 values (highlighted portion) indicate?
Re: Spectre convergence issues device loading failed
Reply #1 - Jun 2nd, 2018, 6:54am
Which spectre version are you using? I suspect it's a little old because I don't think it reports the diagnose messages like that in SPECTRE161 or SPECTRE171 (it gives more useful information as to what each number means). If reported as you're seeing it, it's not terribly helpful, I agree.
Can you try a recent SPECTRE161 or SPECTRE171 hotfix version?
SureshCh
India
Re: Spectre convergence issues - device loading failed
Reply #2 - Jun 3rd, 2018, 9:35pm
Dear Andrew,
Thanks for the reply.
I am using spectre 16.10.567.
Spectre (R) Circuit Simulator
Version 16.1.0.567.isr12 32bit -- 12 Dec 2017
If there is any specific version in 161 and 171 to use, Please let me know.
Thanks!
Suresh
SureshCh
India
Reply #3 - Jun 3rd, 2018, 10:57pm
Andrew Beckett wrote on Jun 2nd, 2018, 6:54am:
Dear Andrew,
I have tried with version 17.10.238. Still the warning shows up:
Warning from spectre at time = 6.22759 us during transient analysis `tran'.
Reply #4 - Jun 4th, 2018, 7:15am
How complicated are the Verilog-A models? I've seen some diode models from a foundry that weren't well formulated; one could get math errors. For a diode, with two terminals, one can easily add a $debug statement to print out values from inside the model. If it's a more complicated Verilog-A model, it might be tedious to print things out and trace down the problem.
SureshCh
India
Reply #5 - Jun 4th, 2018, 7:47am
Geoffrey_Coram wrote on Jun 4th, 2018, 7:15am:
Dear Geoffrey,
There are two va models. one is a poly resistor in which self heating is modeled and the other is detailed mosvar model.
I have also looked at a log file inside "netlist.ahdlSimdb" directory and there was a warning (from GCC) "Woverflow" for a data type. But this does not point to any specific variable inside the verilog A code.
Thanks!
Thanks!
Reply #6 - Jun 11th, 2018, 5:23am
You could replace the poly res with a linear resistor, and conversely replace the mosvar with a linear capacitor, and then see if you still get the problem. (Of course, it could be that it's only the combination that causes problems.)
Reply #7 - Jun 17th, 2018, 3:27am
You may be best contacting Cadence Customer Support at http://support.cadence.com so that an Application Engineer can look in detail at your problem by being able to see the netlist and models.
