Mar 28th, 2024, 5:33pm
FSK Signal Generation Cadence Spectre RF (Read 907 times)
MWJ1975
Sep 02nd, 2018, 7:37pm
I was wondering if there is a method to generate a FSk signal in Cadence. Similar to how 'vsin' and 'vsource' can generate AM and FM signals from the analoglib library.
Looking online, I only saw one method which involved Verilog coding. Is there an easier technique to generate an FSK signal? I was able to generate an OOK signal using a 'vsin' and an ideal switch.
Using Virtuoso Analog Design Environment (ADE L). Thanks.
