Apr 19th, 2024, 4:45pm
Measure the THD of a Transimpedance Amplifier (Read 1281 times)
repah
Sep 09th, 2018, 6:42pm
I want to measure the THD of a transimpedance amplifier that is broadband over tens of GHz.
How would I do this in Cadence Spectre/Virtuoso ?  Do I use PSS ?
Thank you.
Re: Measure the THD of a Transimpedance Amplifier
Reply #1 - Oct 21st, 2018, 11:11am
You could - the Direct Plot after PSS has a THD choice. Alternatively, you could run a transient to find the settled periodic state and then use the thd function in the calculator, but the PSS approach is better as it will ensure you find the settled steady state behaviour of the periodic circuit.
