Mar 28th, 2024, 1:10am
General method for phase-locked loop filter analysis and design (Read 1112 times)
blue111
Oct 16th, 2018, 9:09pm
For this http://sci-hub.tw/https://ieeexplore.ieee.org/document/4490229 General method for phase-locked loop filter analysis and design paper , I have few questions:
1) In section 3 Classification for PLLs , could anyone help to explain on this ? and how to derive this frequency roll-off expression ?
Quote:
The difference between order and type gives a measure of the ability to filter out high-frequency phase noise contribution, in such a way that the high-frequency roll-off is given by the expression: -6.02 * (order – type + 1) dB/octave.
2) Could anyone prove mathematically that "The order needs to be higher than type only when extra attenuation of phase noise is needed" ?
3) Besides, could anyone derive expression (7) ? and how does this inequality expression guarantee that the transient and filtering capabilities of the PLL is unchanged while increasing the hold range (which is proportional to K_pv, according to author ? ) ?
4) For Floyd Gardner's Phaselock Techniques 3rd edition book, how do we derive stability criterion inequality for type 3 digital PLL which is expression (4.23) ?
