Apr 24th, 2024, 5:33pm
Application for Type-I of PLLs (Read 1289 times)
Peelin
Nov 08th, 2018, 10:59am
Type-II PLLs are common, but papers related to Type-I PLLs becomes common and common now.
I do know that the Type-I PLL has the problem of static phase error, and the value of static phase error depends on the Vcont when PLL settles.
So, due to PVT variation, the Vcont that PLL locks is different. i.e. The static phase error is different in different corners.
I want to ask is there any application in industry that can adopt Type-I PLLs? (maybe ADC? or Frequency Synthesizer? ...etc)
vroy_92
Leuven, Belgium
Re: Application for Type-I of PLLs
Reply #1 - Nov 15th, 2018, 12:28am
In the classical type-1 PLL the problem is that the phase correction happens by giving a step increase or decrease in frequency during the static phase offset period. Its like you are trying to maintain a constant distance between your car and a car in front of you. If the other car suddenly goes a little far, you accelerate for a small amount of time and as soon as you are at the distance you stop accelerating.
As you can imagine that would be a very choppy ride.
In terms of PLL, it would have high phase noise.
A better way to implement a type-1 PLL would be sample that static phase error and then distribute it across the entire reference period to align the phase instead of just applying it during the SPO phase. If you can manage to do that, you will get much better PLL performance using a type 1 PLL.
V Roy
