Apr 24th, 2024, 9:02am
2 way switch in verilog ams (Read 1114 times)
Yuan
Feb 06th, 2019, 10:01pm
I was trying to make a 2 branches switch between Vdd and ground, which controlled by a logic signal. Below is my code:
module dg_switch2(p, n, g, s);
   input s;
   output p, n, g;
   logic s;
   electrical p, n, g;
   analog begin
     if (s) begin
         I(p, n) <+ 0.0;
           V(g, n) <+ 0.0;
     else begin
           V(p, n) <+ 0.0;
               I(g, n) <+ 0.0
The problem is that when I connect a Vdc to port'p' and ground to port 'n', cadence report an error says that my there is a short circuit at my Vdc. It seems that I cannot connect both the voltage source and ground to my switch. What should I do fixed the error?
Re: 2 way switch in verilog ams
Reply #1 - Feb 7th, 2019, 8:28am
You should add some resistance.
What do you expect to happen when the switch is closed, V(p,n) <+ 0, and the voltage source Vdc is not zero?
