Apr 18th, 2024, 12:00pm
CMFB loop bandwidth requirement for differential amplifier (Read 776 times)
Salim2019
Mar 15th, 2019, 4:15pm
Dear friends,
I am designing fully differential amplifier and now I would like to know please what is the relationship between the CMFB loop frequency and the differential signal frequency.
can I CMFB loop with frequency less than the differential mode frequency ?
what is the rule of selecting the CMFB loop frequency ?
Thank you in advance
Jacki
Re: CMFB loop bandwidth requirement for differential amplifier
Reply #1 - Mar 17th, 2019, 1:37am
if you want a stable loop, at least your CMFB frequency should be higher than 3dB frequency in the differential mode.
Salim2019
Reply #2 - Mar 17th, 2019, 1:53pm
Dear friend,
Thank you very much for your reply
My CMFB loop is not stable as I came to know that it has higher GBW than the GBW of the differential amplifier and hence polse from differential introduced to it and degraded the stability.
Thus I am going to decrease the CMFB loop bandwidth to improve the stability
