Mar 28th, 2024, 10:29am
Montecarlo Analyses (Read 999 times)
Salim2019
Montecarlo Analyses
Apr 07th, 2019, 2:20pm
I am running Montecarlo in Cadence,
I am using the Random or the Latin method but I don't know how to select the proper value of samples, how much should it be for 3 sigma result
Thanks alsot
Re: Montecarlo Analyses
Reply #1 - Apr 17th, 2019, 1:52am
Which IC version are you using (Help->About in the CIW will tell you)? Are you using ADE XL, or ADE Explorer/Assembler? If you're using ADE XL, do you have access to ADE Explorer/Assembler?
I'm asking so that I can give you a targeted response rather than a long and rambling one that covers the different situations when this is something that has improved over the years and in newer tools.
Kind Regards,
