Mar 29th, 2024, 7:21am
Phase Noise measurement for PLL in closed Loop (Read 1164 times)
thewirehead
India
Nov 10th, 2019, 3:52am
Hello there,
I've been new to this forum, so if this question isn't supposed to be here or is already repeated elsewhere (I have searched all across the forum and I was unable to find the answer) please point me there. Thanks.
My question is that, I have rigged-up PLL schematic at transistor level in 65nm. The PLL is working in all the corners. Now I need to run Phase noise analysis to the complete PLL in closed loop. I'm using Virtuoso 6.17, I tried to run PSS and Pnoise analysis and I faced problem with convergence, I tried it multiple ways failed miserably  :'(.
Could someone take a time help me solve this issue ? Where exactly am I doing wrong ? and are there any other methods than just this.
My PLL specs:
Ref Clock : 100MHz,
Output Clock: 10GHz
Charge Pump Current : 100uA
Should I run Phase noise analysis to each block separately and should I add it up ? Please help.
Thank You..
Re: Phase Noise measurement for PLL in closed Loop
Reply #1 - Nov 10th, 2019, 8:52pm
Use shooting methods, and set tstab long enough so that the PLL reaches lock before the PSS analysis begins.
thewirehead
India
Reply #2 - Nov 10th, 2019, 9:12pm
Thanks a lot Ken, big salute..
You made my day,
I will try this, and get back.
