Apr 25th, 2024, 10:06am
SystemVerilog Behavioral Simulation in Cadence Virtuoso/AMS/Incisive/Spectre (Read 1263 times)
repah
Nov 20th, 2019, 12:36pm
I want to do behavioral simulations using SystemVerilog as opposed to using Verilog-A and Verilog-AMS for Mixed Signal Designs in Cadence Virtuoso/AMS/Incisive/Spectre.
How can I use SystemVerilog files ?  Can I use them just as I use Verilog-A or Verilog-AMS files ?  Will Cadence Virtuoso/Spectre/Incisive/AMS recognize SystemVerilog and just compile and simulate just as with Verilog-A and Verilog-AMS ?  Are there any special considerations in using SystemVerilog with Cadence Virtuoso/Spectre/Incisive/AMS?
I want to run these files in a behavioral testbench within a schematic using blocks in the schematic containing the SystemVerilog files (not from the command line) for modeling something like a PLL, ADC, etc.
Thanks.
Re: SystemVerilog Behavioral Simulation in Cadence Virtuoso/AMS/Incisive/Spectre
Reply #1 - Dec 24th, 2019, 6:49am
You can't use SystemVerilog with Spectre (similarly you can't use Verilog, VHDL, or Verilog-AMS with spectre either, since it requires an event-driven simulator). You can use SystemVerilog with AMS Designer though since that's a mixed-signal simulator, and really there's nothing special you need to do for this. If using ADE, you'd create SystemVerilog textual views, or you can reference external files with a .sv suffix - it just works.
