Apr 23rd, 2024, 10:47pm
Cannot see VCO phase noise (Read 3084 times)
as_rf
Feb 24th, 2020, 11:44am
I have a vco code with jitter and I want to observe phase noise
using PSS and PNOISE simulation. What I see is just a constant line for my phase noise.
`include "constants.vams"
`include "disciplines.vams"
(*ignore_hidden_state*)
module vco (vin, vout);
input vin;
output vout;
electrical vin, vout;
parameter real Vmin=0;
parameter real Vmax=Vmin+1.2 from (Vmin:inf);
parameter real Fmin=1.8e9 from (0:inf);
parameter real Fmax=3e9 from (Fmin:inf);
parameter real Vamp=1.2 from [0:inf);
parameter real ttol=1u/Fmax from (0:1/Fmax);
parameter real vtol=1e-9;
parameter integer min_pts_update=32 from [2:inf];
parameter real tran_time=10e-12 from (0:0.3/Fmax);
parameter real jitter_std_ui=0.002 from [0:1);
real freq, phase, jitter_rad, dphase, phase_ideal;
integer n, seed;
analog begin
@(initial_step) begin
seed = 671;
n = 0;
dphase=0;
jitter_rad=jitter_std_ui*2* `M_PI;
freq = ((V(vin)-Vmin)*(Fmax-Fmin)/(Vmax-Vmin)) + Fmin;
$bound_step(1/(min_pts_update*freq));
if (freq>Fmax) freq = Fmax;
if (freq<Fmin) freq = Fmin;
phase_ideal = 2* `M_PI*idtmod(freq, 0.0, 1.0, -0.5);
phase = phase_ideal + dphase;
@(cross(phase_ideal + `M_PI/2, +1, ttol, vtol) or cross(phase_ideal - `M_PI/2, +1, ttol, vtol)) begin
dphase = $rdist_normal(seed, 0, jitter_rad);
@(cross(phase + `M_PI/2, +1, ttol, vtol) or cross(phase - `M_PI/2, +1, ttol, vtol))
begin
n = (phase >= -`M_PI/2) && (phase < `M_PI/2);
V(vout) <+ transition(n?Vamp:0,0,tran_time);
endmod
[img][/img]
Re: Cannot see VCO phase noise
Reply #1 - Feb 24th, 2020, 8:36pm
Pnoise is a small signal analysis. It only includes noise from small-signal sources, and you have none.
Furthermore, you should not use the jittery oscillator model with PSS as PSS requires periodic solution but the jittery oscillator does not have one.
as_rf
Reply #2 - Feb 25th, 2020, 10:37am
Thank you very much for clarification.
So is there anyway that I make a behavioral VCO and check its phase noise in Cadence virtuoso ? or make a behavioral fixed-frequency oscillator ? Does not have to be VCO.
as_rf
Reply #3 - Feb 25th, 2020, 11:43am
My Goal is to be able to make behavioral PLL (Or circuit) and check its phase noise.
But I am very confused. There is no solid tutorial for this.
Reply #4 - Feb 25th, 2020, 9:31pm
Turn off the jitter and add noise using the small signal noise functions.
as_rf
Reply #5 - Feb 26th, 2020, 12:11am
I dont know how to do that.  :(
Reply #6 - Feb 27th, 2020, 12:31am
Set the jitter parameters to zero, so your system will have a periodic steady state response. And then add functions like flicker_noise and white_noise to the models to inject the small signal noise. These functions were demonstrated in the phase domain models given earlier in the paper.
Reply #7 - Feb 29th, 2020, 4:33am
In addition (once the jitter code has been removed or made inactive to ensure it's periodic) there genuinely is a hidden state in there (you are turning off the hidden state checks). The variable n is only being set within the @cross. You can avoid that simply by writing:
  @(cross(phase + `M_PI/2, +1, ttol, vtol) or cross(phase - `M_PI/2, +1, ttol, vtol));
There's no begin and end - simply put a semi-colon after the @(cross) as this then ensure's there's a timestep at (or close) to the transition. The variable n is then assigned on every step. If I do this, the code runs in PSS without needing the hidden state being ignored (note I removed that too from the code):
input vin;
output vout;
integer n, seed;
analog begin
   // seed = 671;
    n = 0;
   // dphase=0;
   // jitter_rad=jitter_std_ui*2* `M_PI;
  phase=phase_ideal;
//    begin
//    end
Andrew
as_rf
Reply #8 - Feb 29th, 2020, 10:02pm
Thank you very much. But I think still I cannot observe phase noise as explained before.
I wanted to do some voltage domain behavioral modeling for PLL phase noise. But it seems that it is very hard. You spend a lot of time on behavioral model then you regret. It is much easier to make the circuit and do the rest.
In the next step, I want to learn how to plot phase noise of a PLL (schematic design). Still there is no solid tutorial for it.  :-[
Reply #9 - Mar 1st, 2020, 12:32am
Why is it very hard to do the modelling of the noise? Ken already suggested how to do that - it's just a matter of using the flicker_noise and white_noise functions in your Verilog-A models. There are countless models out there that do this, and probably some in these forums too.
