OK, well it's a bit tough if you're using a software release that came out 16 years ago and was last updated 9 years ago. The Rapid Adoption Kit I mentioned in the other post is not going to help you very much then...
If I remember rightly, the wavescan calculator had a spectrum function - but I may be mistaken as to when that was introduced. You should check the documentation.
You really should look into trying to use a software release from at least the last 5 years!
