Apr 17th, 2024, 10:44pm
ENOB - from SDR, SNDR, SFDR, ? (Read 740 times)
repah
Apr 21st, 2020, 3:22am
ENOB of a DAC or ADC - is it from the SDR, SNDR, or SFDR ?
I see various textbooks and application notes reference ENOB from these various sources.
Which is correct ?
DanielLam
Re: ENOB - from SDR, SNDR, SFDR, ?
Reply #1 - Apr 21st, 2020, 1:33pm
SDR doesn't exist, I think you mean SNR.
ENOB usually comes from SNDR. If there is no distortion, then SNR = SNDR because the distortion terms are negligible.
For a sine wave, enob = (sndr - 1.76)/6.02
If a different waveform is used (eg triangle waveform), the equation is sightly different.
