Oct 4th, 2023, 2:26am
ADC Verilog-A Model Symbol View (Read 995 times)
alexshel44
Calgary
Apr 28th, 2020, 10:05am
Hello Everyone,
I am working through the book 'The Designer's Guide to Verilog-AMS' in chapter 3 listing 26 there is a model for an ideal ADC. I fully understand the code however I am having difficulties generating a symbol view in Virtuoso due to variable number of bits. If I instead set the number of bits to a constant everything seems to work properly.
When I generate the symbol view with the variable number of bits it gets an error on the output bin which is defined as out<0:bits-1> where bits is a variable.
Does anyone have any advice for how I can get this to work?
I'm not sure what versions are relevant but, I am using Virtuoso 6.1.7.
Thanks a lot,
Alex
alexshel44
Calgary
Re: ADC Verilog-A Model Symbol View
Reply #1 - Apr 28th, 2020, 10:11am
I just found the modification to this listing that is posted on this website. https://designers-guide.org/verilog-ams/dg-vams/ch3/ch3-listing26.tgz
I guess this is just a feature that doesn't work in spectre anymore. Does anyone have more insight into why this is the case?
Alex
Frank Wiedmann
Munich, Germany
Reply #2 - Apr 29th, 2020, 2:40am
Reply #3 - Apr 29th, 2020, 1:23pm
Spectre is not ADE. The limitation is in ADE not Spectre, and it has always been there. I put the examples in the book without checking that they were compatible with ADE.  That was my mistake. Sorry about that.
