Apr 19th, 2024, 9:01pm
Unusal FFT of the ADC Output (Read 1396 times)
niloun
Oct 31st, 2020, 12:34am
Hi Everyone,
I'm getting an unusual FFT from my ADC output. I have attached an image of the FFT here. Could you please tell me what is happening here?
polyam
Re: Unusal FFT of the ADC Output
Reply #1 - Oct 31st, 2020, 6:19am
What did you apply to the ADC? Is it a single tone? Can you DAC the output of the ADC to see what you get?
niloun
Reply #2 - Oct 31st, 2020, 11:25pm
polyam wrote on Oct 31st, 2020, 6:19am:
Thanks for your response polyAM.
The input is a single tone sinusoid wave. The input frequency is 387.5M Hz, and the sampling frequency is 800M S/s (Nyquist frequency). The type of ADC is Time-Interleaved ADC.
I use Matlab for signal processing. Here is the reconstructed output:
polyam
Reply #3 - Nov 1st, 2020, 7:45pm
Are you sure you are correctly DACing the output signal ? Clearly the amplitude of your output signal is being modulated. Maybe you need to check your demux. I am guessing there is something wrong with the demux. I did a quick simulation for a TI-ADC. Please see the input and output of the ADC. You should be able to see your input signal (of course with a delay) when you DAC the output of the ADC.
niloun
Reply #4 - Nov 1st, 2020, 8:13pm
polyam wrote on Nov 1st, 2020, 7:45pm:
Since I'm doing the sampling in Nyquist frequency, I think I should see the modulation. If you decrease the sampling frequency to less than half you should see the same thing. Let's say you have Nfft=64 Cycles=31 then if your sampling frequency is 800M S/s your input frequency must be 800*31/64 which is 387.5M Hz. If you run the simulation for at least Nfft*(1/Fs) seconds then you will see the same thing.
I have also done the simulation for less than Nyquist frequency (1/10), and my DAC output looks more like yours.
polyam
Reply #5 - Nov 2nd, 2020, 2:26pm
Likewise, I am using the same approach. My sampling frequency is fs=2GHz (BW=1GHz) and I am running 2048 FFT points for 191 cycles. That results in an input frequency of (191/2048)*fs. So, I am not indeed down-sampling and I can do FFT. My suggestion is to trace the signal from the input, output of the T&H, check each sub-ADC individually and the output of the demux. Run FFT at each node and see if your single-tone is there.
Also my simulation time is NFFT/fs. Also I considered a couple of cycles for transient.
« Last Edit: Nov 3rd, 2020, 1:20pm by polyam »
