Apr 19th, 2024, 1:10pm
Question on Channel Length modulation (Read 873 times)
Sharath Raju
Jan 01st, 2021, 2:49pm
Pls see figure attached for context.
I was reviewing Razavi book and had the following question: For a common source stage with resistive load, why is channel length modulation *more* significant for larger values of RD?
Sharath
polyam
Re: Question on Channel Length modulation
Reply #1 - Jan 4th, 2021, 11:28am
Channel length modulation causes a non-zero slope in the IV characteristics of the transistor and the slop is inversely proportional to the output resistance i.e. slope=1/ro (ro=rds).  The steeper slope (channel length modulation) you have the less output resistance  you will get. Now let's have a look at the gain of the CS. It is
Av=gm(RD || ro).
What happens now? your ro is becoming smaller (due to channel length modulation) while your RD is large. So,
Av=gm(RD || ro) becomes approximately Av=gm ro (for a large enough RD). That actually represents the intrinsic gain of the transistor.
Another way to look at that is replacing the RD with an ideal current source (with an infinite output resistance). You will see then ro dominates the equivalent output resistance.
Sharath Raju
Reply #2 - Jan 4th, 2021, 11:42am
Thanks Polyam. Your explanation is very good.
