Jan 13th, 2026, 4:14am
Identifier has conflicting contexts. (Read 2255 times)
manish123456
Oct 14th, 2022, 7:10am
i am getting issue into my verilogams code
 vrefout = (3E-5)*(cf_trim_dec**2) - (0.0044)*(cf_trim_dec) + 0.653;
it is saying vrefout   Identifier has conflicting contexts.
i defined
real vrefout;
Re: Identifier has conflicting contexts.
Reply #1 - Oct 14th, 2022, 11:19pm
A variable is associated with the discrete kernel if it is initialized or if it is assigned a value in an initial block or an always block.
A variable is associated with the continuous kernel if it is assigned a value in the analog block.
A variable with conflicting conflicts is associated with both kernel.
If you want further help, you should show your model.
Reply #2 - Mar 6th, 2023, 7:59am
Do you initialize it somewhere else in your code?
 vrefout = 0;
