Dec 17th, 2025, 3:56am
Why use macros to define Verliog-A model/instance parameters? (Read 4762 times)
TomH_vams
USA
Jun 26th, 2024, 2:08pm
Some verilog-a compact models heavily use macros to define model & instance parameters.
What is the purpose and benefit of this, compared to just using conventional parameter declarations?
Some examples from ASMHEMT 101.4, which defines nearly 40 such macros:
`define MPRnb(nam,def,uni,        des) (*units=uni,                   desc=des*) parameter real    nam=def;
`define MPRex(nam,def,uni,exc,    des) (*units=uni,                   desc=des*) parameter real    nam=def exclude exc;
`define MPRcc(nam,def,uni,lwr,upr,des) (*units=uni,                   desc=des*) parameter real    nam=def from[lwr:upr];
`define MPRoo(nam,def,uni,lwr,upr,des) (*units=uni,                   desc=des*) parameter real    nam=def from(lwr:upr);
`define MPRco(nam,def,uni,lwr,upr,des) (*units=uni,                   desc=des*) parameter real    nam=def from[lwr:upr);
`define MPRoc(nam,def,uni,lwr,upr,des) (*units=uni,                   desc=des*) parameter real    nam=def from(lwr:upr];
`define MPRcz(nam,def,uni,        des) (*units=uni,                   desc=des*) parameter real    nam=def from[  0:inf);
`define MPRoz(nam,def,uni,        des) (*units=uni,                   desc=des*) parameter real    nam=def from(  0:inf);
etc
and a few specific uses in ASMHEMT:
`MPRco( tnom           ,27.0           ,"deg C"       ,-`P_CELSIUS0,inf         ," Nominal Temperature in degree Celsius" )
`MPRcc( voff           ,-2.0           ,"V"           ,-100.0      ,5           ," Cut-off voltage" )
`MPRoo( kt1            ,0.0e-3         ,""            ,-inf        ,inf         ," Temperature Dependence for Voff" )
etc
I asked one of the original asmhemt developers about this, and he replied "the EDA publisher(s) wanted it".
I've seen same method used in PSP, MSIMCMG, and other compact models, so it's not simply a developer's preference.
What is advantage vs using simple parameter declarations?
Is it a convention that I'm simply unaware of?    Where would I find the relevant style manual? (I'm not a CMC member)
Re: Why use macros to define Verliog-A model/instance parameters?
Reply #1 - Jun 27th, 2024, 8:48pm
I don't know, but if I were to guess, it is due to limitations in the various simulators they are supporting. By using defines, they can keep their standard definition of the model constant for all simulators, with the adaptation of the model to particular simulators using simulator specific defines.
