Dec 17th, 2025, 3:57am
Help with 3 Key Questions on Analog Circuit Design & Verification (Read 388 times)
Vodka_JON7
Oct 14th, 2025, 1:01am
Hi everyone,
I’m currently working on analog circuit design and verification and have run into a few confusing points. I’d really appreciate it if anyone with experience could share their insights! Here are my questions:
1. Most specs for analog circuits focus on performance. When we design circuits like LDOs, opamps, or PLLs, our core goal is essentially to create circuits with sufficient performance. If a circuit fails to meet the predefined performance metrics, it’s considered unqualified in the system. Conversely, a circuit that meets performance requirements will also fulfill its intended system functions. This makes me wonder: How do we distinguish between "performance" and "function" for analog circuits?
2. Is UVM-MS the ultimate solution for analog and mixed-signal verification? In a way, simulations like AC, DC, stb, and noise analysis all represent different perspectives on transient simulations. However, UVM-MS focuses more heavily on tran simulations. This leads me to ask: Can the UVM-MS framework replace traditional analyses like AC, STB, or PSS  simulations? When I use UVM-MS, I keep questioning whether it covers everything needed. I also want to understand: What’s the fundamental difference between relying on UVM-MS versus using AC/PSS/STB simulations?
3. For analog circuits in general, how do we build a complete verification flow? And more practically, how can we prove that a designed analog circuit is truly qualified? This is another key confusion I haven’t been able to resolve.
Thanks in advance for any advice or discussions—your input would be a huge help!
Best Regards
Lewis
Re: Help with 3 Key Questions on Analog Circuit Design & Verification
Reply #1 - Oct 28th, 2025, 10:07pm
The way I distinguish performance and function is as follows:
  • The performance of a circuit varies with small changes in parameter values.  The circuit fails a performance check if the performance does not satisfy a minimum requirement.  Given the nature of performance, it is conceivable that small changes to parameters could cause the performance check to pass.
  • Circuit function is not affected by small changes in parameter values.  For example if a wire is broken so that the signal cannot pass through the circuit, that is a functional failure.  Small changes in parameter values in the circuit cannot fix this issue.
Examples of functional failures:
  • an inverted enable
  • a logic error
  • a swapped bus
  • a polarity error
  • a loop of dependencies (bias block depends on LDO, but LDO depends on bias block)
  • etc.
Example of performance failures:
  • insufficient gain
  • insufficient bandwidth]
  • too much noise
  • etc.
Reply #2 - Oct 28th, 2025, 10:27pm
Analog and mixed-signal verification are the same thing.  Virtually all analog circuits on modern analog system ICs have digital controls.  So you can say you are verifying an analog circuit or you can say you are verifying a mixed-signal circuit.  It is the same thing.  I am a proponent of using the term: analog verification.
I have been focused on analog verification for many years, and I have never used nor considered using UVM-MS.  When I looked at it my conclusion was that it was an attempt to apply digital verification techniques to analog circuits, and it never seemed like a good fit to me.  I got what I needed from plain Verilog-AMS, and I found it was a better fit.
UVM-MS and Verilog-AMS are used mainly for functional verification.  Both employ transient simulation.
The small signal analyses, by their nature, are used for performance verification.
Verilog-AMS can also be used for performance verification but it tends to be used for different performance metrics.  The small signal analyses are used to measure performance metrics associated with small-signals such as bandwidth, stability, noise, etc.  Transient analysis base simulation techniques are more suited metrics associated with large signals and are used to extract inherently nonlinear behavior such as distortion or locking behavior in PLLs.
Reply #3 - Oct 28th, 2025, 10:34pm
Fundamentally a complete verification flow includes both performance and functional verification.  Knowing how much to do is something that comes from experience.  Of course you should verify all required specs and all required functionality.  This later requirement means that you must exercise all modes and settings.  Most analog circuits these days do not contain significant state (digital state machines), so functional verification largely requires exercising all digital wires that connect to the circuit.
