S. Badel
That's because you are picking data from the operating point analysis (dcOp) which is run once at the beginning of the simulation.
When doing a parametric sweep, you are actually running multiple simulations, so the operating point is saved for each point and you can get a curve.
as for other parameters, getData("/M0" ?result "dcOp")~>? will list all dc operating points parameters that are available such as gm, gds, vdsat etc.
all should be documented in the simulator's reference manual.
stéphane
