zhong
California , United States
Normally, ncelab should pick up what you have binding in HED .
Two exceptions .. 1. CONFIG_MODELPATH .. As Andre indicated
Regarding CONFIG_MODELPATH YES , it solve the binding issue when you have same cell , one instance binding to module view , another one binding to spice netlist (via source file or modelpath) . If you have such case, then setenv CONFIG_MODELPATH YES is way to go.
2 HED config did not get update If it does not resolve the problem, the other possibility is that , after you change the HED view binding , you did not update it. In such case, config/expand.cfg did not get update and ncelab will pick up the old view . Please also update the HED and re-run the simulation ...
zhong
