Write a script to do this.
First, create a template - fill in the values on the form, and save the template.
Then, with your script, loop over the files one by one, and create a new template with the input file name stuffed into the template at the right place (it's pretty obvious if you look at the file).
Then in the script, run "pipo strmin yourNewTemplate" - for each gds file.
It's pretty straightforward to do this...
