This is probably more of an Ocean-related question than anything else, but I hope someone can help!
I basically just want to 1) run a batch of transient simulations, each of which uses a different pwl file to control a stimulus, and then 2) export the data from each run to files with a matlab-friendly format for post-processing. Part 1) works, part 2) does not.
I am using an Ocean script to orchestrate everything.
1) (WORKING) To run the simulations, I am using alter statements, similar to the advice of MightyMouse in this thread:
http://www.designers-guide.org/Forum/?board=circuit;action=display;num=110806886...The only catch is that I am (mis?)using the
stimulusFile() command in Ocean to include a custom file in input.scs, which actually has all the "alter" commands in it. But I don't think that is a problem. All this actually seem to be working. When I run my Ocean script, multiple simulations are run, and if I launch the Results Browser in the Virtuoso ADE, I can see all the results from each run and plot data and everything looks good.
2) (NOT WORKING) I am having trouble getting Ocean to select among the various transient runs. If I use the
results() command, I get a list of things that include items like the following: "tran1-tran" "tran3-tran" "tran4-tran" (for some reason, "tran2-tran" is always missing from this list). And if I go to the Ocean command line, I can see that each of these brings up a valid pointer when used with
selectResults. E.g.
ocean> selectResults("tran1-tran")
stdobj@xa2f81b0
ocean> selectResults("tran2-tran")
stdobj@xa2f81bc
etc.
BUT, if I follow that with, say
plot(VT("/dac_in")), then it ALWAYS plots the results of tran2. This is the heart of my problem. No matter which results I try to select, I only get tran2. Consequently, I cannot plot/print anything from any of the other simulations.
Is there something I don't understand about how
selectResults works? I feel like this is a bug, but I am too new to be sure.
I would appreciate help of any kind...either workarounds for the
selectResults problem or advice on completely different ways to run this batch of simulations.
thanks!
