loose-electron wrote on May 19th, 2008, 2:09pm:Sounds to me like the model path definition is missing.
Is it only the mim that is complained about? Are you sure the model/subckt name that appears in the netlist is the same as the one that appears in the model library?
Some model libraries use complicated systems of including different sections, with parameters set for various corners; I did see one where a diode was not available in one corner because the appropriate .include was missing; you might try to trace the inclusion of the mim modelcard/subckt.
