Aug 15th, 2024, 8:17pm
plotStyle() isn't valid for Cadence Wavescan. (Read 8153 times)
Jul 18th, 2008, 5:56pm
Hi.
Spectrum is plotted with bar style automatically in Cadence Wavecan,
so I would like to change its style to "joined" using skill or ocean function.
I use plotStyle( ’joined ) for this purpose in Cadence AWD.
But this plotStyle() isn't valid for Cadence Wavescan.
What function is available for changing plot style in Cadence Wavescan ?
« Last Edit: Jul 19th, 2008, 3:11am by pancho_hideboo »
Re: plotStyle() isn't valid for Cadence Wavescan.
Reply #1 - Nov 28th, 2008, 8:15pm
Any expert of Cadence Tool.
Teach me if any idea.
Reply #2 - Jan 2nd, 2009, 8:47am
Huh?
plotStyle() is supported when wavescan is the waveform tool. I knew this worked, but I just checked, in case it had broken and I'd not noticed... well, it work correctly.
The only downside is that wavescan supports more modes than AWD did, and they're not all available via plotStyle() (I think I have a CCR for this), but in general that's not a big problem.
Reply #3 - Jan 6th, 2009, 8:18pm
Andrew Beckett wrote on Jan 2nd, 2009, 8:47am:
Still plotStyle('joined) doesn't work.
Attached figure is Wavescan.
Quote:
;ocnWaveformTool('awd)
ocnWaveformTool('wavescan)
awvSetOptionValue('dateStamp t)
awvSetOptionValue('displayGrids t)
awvSetOptionValue("cursorPrecision" 9)
awvSetOptionValue("displayAxesBy125" t)
pi = acos(-1.0)
date = getCurrentTime()
Title = "Confirmation of plotStyle()"
wid = newWindow()
addTitle(Title)
bid = currentSubwindow(1)
base_dir = "./"
sim_data = "qpss_hb3.raw"
openResults( strcat(base_dir, "/", sim_data) )
selectResult("qpss_fd")
Vif=getData("Pif")
plot( db20(Vif) ?expr '("Spectre") )
plotStyle('joined)
;plotStyle('bar)
yLimit( list(-100, 0) )
awvSetXAxisLabel(wid "frequency [Hz]"  ?subwindow bid)
awvSetYAxisLabel(wid 1 "Vif [dBV]" ?subwindow bid)
Reply #4 - Jan 6th, 2009, 8:22pm
Attached figure is AWD.
In this case, plotStyle('joined) does work.
Reply #5 - Jan 6th, 2009, 11:08pm
I'll look into this and get back to you. It worked when I tried it before I posted - so I'll see if I can repeat your problem, and understand why it happens...
Reply #6 - Jan 7th, 2009, 9:40am
It seems that there's a bug - it doesn't allow you to set it to joined if the waveform being plotted already has the plotStyle set to "bar". This will be true of some waveforms coming from simulation, but not all - which is why it worked for me, but didn't work for Pancho Hideboo.
I'll file a CCR for this.
In the meantime, if you do this:
Vif=getData("Pif")
Vif->plotStyle='joined ; could be set to nil too
in your code, it will then work.
This workaround works regardless of using wavescan or AWD.
Reply #7 - Jan 7th, 2009, 4:28pm
Andrew Beckett wrote on Jan 7th, 2009, 9:40am:
Vif=getData("Pif")
Thanks. This can work.
Reply #8 - Jan 8th, 2009, 9:59am
I filed CCR number 628706 for this.
