Dan,
I suspect the best thing to do here would be to contact Cadence customer support - it's hard to debug this kind of thing without seeing it, and they could always do a web session with you to take a look.
The two netlisters are there to support different setups. If you have "ams" CDF simInfo for your PDK, then the cell-based netlister will work - if you don't, then you either need to set it up (there's a tool in the Tools->Conversion Toolbox in the CIW for this), or use OSS. The OSS netlister essentially uses the spectre CDF simInfo and translates. I wouldn't say that you shouldn't use OSS, but do make sure you're using a recent ISR of the IC environment as there have been a number of fixes over recent months.
