Aug 16th, 2024, 11:23am
Cadence EDGE to CDB conversion (Read 4193 times)
Girish
Mar 18th, 2009, 10:21pm
 I have a database in Cadence EDGE format. From what i understand this was a database format from cadence being used in 90's. Is there a way to convert it to a format which one of today's tools can read.
Cadence believes that the conversion can happen using IC4.2.x and IC4.4.1 which would convert it from EDGE to someformat to a format which IC5x can read. Does someone have access to these binaries?
Girish
Re: Cadence EDGE to CDB conversion
Reply #1 - Mar 22nd, 2009, 11:40pm
Actually you should be able to do it with 4.3.4 (9502) to get to 4.3.X format, and then translate that using a version between 4.4 and 4.4.6 to get it into a database that can be read with IC5141.
Unless you've got software and hardware that can run these versions, I'd say it's going to be quite tricky.
Girish
Reply #2 - Mar 24th, 2009, 5:02am
Thanks Andrew for the response. Where can i get the binaries for these versions. Apparently, cadence is finding it difficult to find these tool versions.
Girish
Reply #3 - Mar 30th, 2009, 9:26am
Presumably if you have designs on these old versions, you archived the software media, the OS, and the hardware along with it?
