Jul 18th, 2024, 11:17pm
a problem using AMS (Read 2291 times)
Ken Wong
Taiwan
a problem using AMS
Mar 28th, 2009, 11:04pm
I am using AMS simulator to tset a verilog-coded bolock in spectre.
After I set up the config, I choose "Mixed-Signal>>Interface Element>>Instance" for a2d and d2a setting, but it just reply "please select an instance to update". How can I solve the problem.
thanks a lot.
Re: a problem using AMS
Reply #1 - Mar 30th, 2009, 9:20am
The mixed signal menu is for the older SpectreVerilog simulator interface; it is NOT for AMS Designer.
For AMS Designer, you control the connectmodule (interface elements are instances of connectmodules) by altering connect rules via the Setup->Connect Modules in the ADE window (assuming you're simulating via ADE), and then use the AMS->Default Discipline Selection if you need to specify a particular discipline for parts of the design. If you really need to that is...
It sounds as if you're getting the two mixed signal simulators mixed up? (apologies for the dreadful pun there...)
