Jul 17th, 2024, 10:22pm
Pages: 1 2
op amp simulation question (Read 3261 times)
liletian
MD
Apr 27th, 2009, 8:29am
Hi Guys
I simulated a op amp feedback circuit as attached, it is wired the output has DC offset of 0.004 voltage, can anyone explain it? The input is a Vsin of 2Ghz without dc offset in the negative input, the positive input is connect to ground, I will expect there has no output DC offset. Can anyone explain it? please see the attachment. The op amp is an ideal op amp with gain of 1e10.
Thank you
LeeX
Singapore
Re: op amp simulation question
Reply #1 - Apr 27th, 2009, 9:19am
Is this op-amp ideal or is it some circuit you have designed?
Also, for the configuration shown in the fig, what kind of task you expect the circuit to perform?
liletian
MD
Reply #2 - Apr 27th, 2009, 9:37am
LeeX wrote on Apr 27th, 2009, 9:19am:
The Op-amp is ideal, it is mathmatic equation( using verilogA), I would expect this circuit to work as an amplifier with a gain. I would not like to see a DC offset in there. Very weird.
raja.cedt
Reply #3 - Apr 27th, 2009, 9:58am
hi liletian,
              i didn't understand what's your plan with this circuit?As you said if you want amplifier why did you kept that cap in the feedback and even you don't have any dc source in the circuit,how would you expect dc offset.
Rajasekhar.
liletian
MD
Reply #4 - Apr 27th, 2009, 10:17am
raja.cedt wrote on Apr 27th, 2009, 9:58am:
hi liletian,
Rajasekhar.
I do not expect DC offset, but my simulation gives me DC offset, that's why I am so confusing. Embarrassed
buddypoor
Bremen, Germany
Reply #5 - Apr 27th, 2009, 10:20am
Hi  liletian,
as already mentioned before: what is the purpose of the feedback capacitor ? It destroys your dc operating point (no dc feedback).
The circuit cannot work.
liletian
MD
Reply #6 - Apr 27th, 2009, 10:24am
buddypoor wrote on Apr 27th, 2009, 10:20am:
Hi  liletian,
It can work, why it can not work, the signal is a RF signal. The circuit is for charge pump purpose.
salty
Austin, Tx
Reply #7 - Apr 27th, 2009, 10:46am
My guess is numerical resolution.  The only reason this ckt "works" is because everything is ideal.  If you see 4mV on the output, that would imply 400fV on the input which is about 2^-41.  I think you are just seeing numerical issues.  If you have very much DC at all on the input of the amplifier with 10^10 gain, the amp will rail.  You have no DC path around the amplifier.
buddypoor
Bremen, Germany
Reply #8 - Apr 27th, 2009, 1:33pm
liletian wrote on Apr 27th, 2009, 10:24am:
Please, excuse me. But I think its absolutely silly to use an artificial amplifier with a gain of 1E10 without a stable bias point and to worry about an offset of 4 mvolts. Simulation programs are a tool to simulate real circuits which cannot be analyzed with calculations by hand.
liletian
MD
Reply #9 - Apr 27th, 2009, 2:28pm
buddypoor wrote on Apr 27th, 2009, 1:33pm:
for my defense, actually for a gain of 500, there still has 4 mV DC offset.
subgold
Reply #10 - Apr 27th, 2009, 3:25pm
liletian wrote on Apr 27th, 2009, 2:28pm:
could you pls post your verilogA code?
boe
Reply #11 - Apr 28th, 2009, 6:09am
BTW, what is your output voltage? If the Gain is actually 500 [at DC] and you want 2 V at the output, you need 4 mV at the input.
B.O.E.
LeeX
Singapore
Reply #12 - Apr 28th, 2009, 11:02am
I think I may have found how you get the 4 mV "offset".
First of all, I do not think this configuration can work for any practical design, as no DC feedback is present.
However, for the ideal op-amp, I assume it works properly and by "offset" you refer to the difference between zero cross points for the input and output.
The transfer function between input and output is
Vout/Vin=1+1/(jw/(1/RC))
where w is the angular frequency, in your case it is 2G*2*Pi, R=10K and C=200fF, according to your circuit.
Thus
Vout/Vin=1-j0.03978
So Vout is actually shifted in phase and amplified in magnitute, comparing to Vin,
the phase shift is
-0.03978
so if Vin = 0.1*Sin(wt)
Vout is approximately
Vout = 0.1*Sin(wt-0.03978)
let t=0,
Vin = 0
Vout = -0.00397≈4 mV
Actually, by definition the word offset should refer to the voltage difference between the op-amp positive and the negative input when the output is zero (common mode).
If my guess is right, you are measuring the voltage difference between the output node and input node, non of them are the opamp input.
liletian
MD
Reply #13 - Apr 28th, 2009, 1:35pm
 HI
 Thanks for answering, you might be right, I will think about it more. I do know there is no DC feedback, but it seems is necessary for a charge pump of PLL, not sure about it yet. Can you comment more on the DC feedback and why it should not working for any pratical circuits?
 Thanks a lot
LeeX wrote on Apr 28th, 2009, 11:02am:
Thus
Vout/Vin=1-j0.03978
the phase shift is
-0.03978
let t=0,
Vin = 0
buddypoor
Bremen, Germany
Reply #14 - Apr 28th, 2009, 11:28pm
liletian wrote on Apr 28th, 2009, 1:35pm:
 HI
 Thanks a lot
[/quote]
Each opamp needs dc feedback to fix the bias point.
Without dc feedback the offset drives the output in saturation.
Pages: 1 2
