Jul 18th, 2024, 1:24am
spectreVerilog netlist problem (Read 110 times)
jsun
May 09th, 2009, 4:32pm
Hi
While I used spectreVerilog for mixed-signal simulations, while netlisting I got the error message:
"The analogLib library you have currently loaded is not convenient
for simulator spectreVerilog".
Does anybody know what it means?
Thanks a lot!
JS
Berti
Re: spectreVerilog netlist problem
Reply #1 - May 11th, 2009, 12:21am
Hi Jsun,
I had recently a similar problem. The reason was that those id##ts from the fab defined the required view for simulation depending on the simulator (spectre-> spectre view, spectreverilog -> spectreverilog view etc.)
Adding
UARTspectreVerilogStopViewList="spectre"
setq UARTStoreMenusInCurrent t
loadi(strcat(getShellEnvVar("UNICAD_KERNEL_ROOT") "/Uker.ile"))
in your cds.init file should work-around the problem.
Cheers
jsun
Reply #2 - May 11th, 2009, 4:30pm
Hi Berti,
Thanks a lot! It works now... Smiley
js
