Jul 19th, 2024, 5:24am
ideal transformer modelling (Read 2157 times)
tarullim
May 11th, 2009, 9:14pm
hi there,
I am trying to model an ideal two winding transformer, 1:n turns ratio.  I have tried to put two dependent sources, a current controlled current source on the primary and a voltage controlled voltage source on the secondary.  However upon compiling and elaborating, I receive an error message indicating that the instance of the current controlled current source can only have 2 terminals, but has 4.  If I am not mistaken, the proper syntax for the current relationship is I(p,n) <+ gain*I(ps,ns)?  The Verilog AMS book states this is the proper syntax.  I'm not sure why it doesn't work.
Any help is greatly appreciated, thank you in advance
Re: ideal transformer modelling
Reply #1 - May 14th, 2009, 7:03am
It's not clear to me what your "current controlled current source" is: did you write a Verilog AMS model for it, or are you using a SPICE element?  I think Spice3f5's CCCS uses a voltage source for its current probe.  If you write your own VAMS model, with the syntax you suggest, then obviously you'd need to have a module with four ports.
