trashbox
Hi all, I'm using hspice to run Monte Carlo simulation and puzzled about the following questions: #1. How many iterations is ok for MC simulation? If I set iteration very large, it'll spend too much simulation time.
#2. The foundry documentation shows I should set PROCESS Variability and MISMATCH respectively. So what's the difference between PROCESS Variability and MISMATCH? I ever think mismatch is the result of process variability.
#3. If I run MC simulation, should I also set corner? What's the difference between corner (fast/slow/typical) and Monte Carlo?
Thanks in advance!
