Jul 17th, 2024, 4:36pm
ncelab error (Read 4580 times)
Dipankar
ncelab error
Aug 04th, 2009, 5:03pm
Dear All,
                I am facing the following error in AMS at ncelab phase.
" .... Discipline resolution Pass...
Doing auto-insertion of connection elements...
NO_GOOD_PKT ), .ACK_processing( ACK_processing ), .......
ncelab: *E,CUVNAS (./ihnl/XXXXX/ZZZZ/schematic/verilog.vams,540|10): segmentation of  a signal  between analog ports is illegal.... "
background : trying to run spice level simulation of a digital block with the CDK of std-cell used. Now when I use functional views of the cdk cells the simulation goes fine. But when I use schematic view of the cdk cells in certain modules I face the above issue. Agian for those certain modules if I  use functional view things go fine.
Can anyone help ?
With Thanks and Regards,
Dipankar.
Riad KACED
Swindon, UK
Re: ncelab error
Reply #1 - Aug 12th, 2009, 10:38am
Hi Dipankar,
I had a similar problem a few while back. It was actually a design problem where I was doing a digital check (check whether a signal was high or low) when simulated the design in the analog domain.
You can do some debugging by giving the -chkdigdisp argument
to ncelab to tell it to output details of the discipline resolution.
BTW, can you share more information about your design ? This is very likely to give us better ideas.
Cheers,
Riad.
Riad KACED
PDK, EDA Support Engineer.
