Jul 17th, 2024, 10:32am
using binary numbers in VerilogA (Read 10290 times)
hali
Feb 12th, 2010, 6:46am
Hi.Can anyone tell me that can I use binary numbers in verilog A .e.g can i assign( integer i=0100); if no wat is the way to use binary numbers in verilog A? Embarrassed
Re: using binary numbers in VerilogA
Reply #1 - Feb 12th, 2010, 7:56am
hali wrote on Feb 12th, 2010, 6:46am:
There is no direct method which is available in Verilog-D or Verilog-AMS.
It is same as C-language.
i = 0*(1<<3) + 1*(1<<2) + 0*(1<<1) + 0*(1<<0);
Quote:
integer iflag, i, j, a, d;
integer x, h;
real test;
analog begin
  @(initial_step) begin
     iflag = 0;
     d = 1;
     x = 0;
     for(i=0; i<=REGISTER_LENGTH;i=i+1) begin
        x = x + (1 << i);
     if(REGISTER_LENGTH == 15)
        h = (1 << 0) + (1 << 14) + (1 << 15);
     else
        h = (1 << 0) + (1 << 5) + (1 << 9);
  end // initial_step
  @(timer(Clock_Period/10, Clock_Period)) begin
     if(iflag > 0) begin
        a = x & h;
        j = 0;
        for(i=1; i<=REGISTER_LENGTH;i=i+1) begin
           j = j ^ ((a >> i) & 1);
        x = x & (~1);
        x = x ^ j;
        x = x << 1;
     iflag = 1;
  end // timer
« Last Edit: Feb 12th, 2010, 8:57am by pancho_hideboo »
Reply #2 - Feb 15th, 2010, 9:23am
Slightly confused by Pancho Hideboo's response, as in Verilog you can do:
i=4'b1010;
to assign a 4 bit binary number to an integer.
hali
Reply #3 - Feb 15th, 2010, 9:25am
thanks pancho.Ur reply really helped me a lot:)thanks once again
Reply #4 - Feb 15th, 2010, 9:26am
Andrew Beckett wrote on Feb 15th, 2010, 9:23am:
i=4'b1010;
This is not valid for Verilog-A.
Reply #5 - Feb 15th, 2010, 9:32am
And you can do this in VerilogAMS (not spectre's VerilogA though):
analog begin
    @(initial_step) i=4'b1011;
