Aug 3rd, 2024, 7:19am
temperature variation on AMS transient simulations (Read 7932 times)
HdrChopper
Jun 05th, 2010, 2:26pm
Is there any way to run transient simulation in AMS where the temperature is slowly varied?
Thanks for your comments.
Tosei
Keep it simple
boe
Re:  temperature variation on AMS transient simulations
Reply #1 - Jun 25th, 2010, 7:59am
thechopper,
Yes. Use something like (example from Cadence Spectre Circuit Simulator Reference):
tran1 tran stop=0.5u param=temp param_vec=[0ns 20 50ns 25] param_step=10ns
"In this tran run, the temperature is interpolated with slope (25-20)/(50ns-0ns) and updated every param_step (10ns)."
Hope this helps.
BOE
[Added:] Also this is from Spectre documentation, it also works with AMS.
Reply #2 - Jul 7th, 2010, 8:06am
Hi Guys,
It's really interesting to run a transient simulation while temperature varies slowly. However, how do I plot temperature variation vs. time in AWD or wavescan after the transient simulation finishes.
Yawei
HdrChopper
Reply #3 - Jul 15th, 2010, 7:02pm
Thanks for your answer, boe.
I knew in Spectre such simulation could be run, but I was not aware there was such an option in AMS environment.
I'll try it out then.
Best
Tosei
Keep it simple
boe
Reply #4 - Sep 2nd, 2011, 5:50am
ywguo wrote on Jul 7th, 2010, 8:06am:
.... However, how do I plot temperature variation vs. time in AWD or wavescan after the transient simulation finishes.
Yawei,
Add the following line to your Spectre netlist: Code:
save temp
This enables saving of the temperature.
B O E
