Is the file at that location? My guess is no, that you have an installation problem because I expect to see "cadence" or "cds" in the start of the path, instead of just /usr. What's the path to the program/binary you are running? Can you find libdcapi.so in the same directory tree? (If you are running /usr/applications/cadence/something/version/linux/bin/myexe, then look in /usr/applications/cadence/something/version/linux/lib/)
