Choose the signal you want to plot in Results Browser after first run. In pss-td.pss, choose the signal, RMB click and select Calculator. Then the signal is put in the Calculator, looks like v("signal_name" ?result "pss-fd.pss").
After that, choose Outputs --> Setup in ADE. Get the expression from the Calculator and name it. Click OK or Apply to add the expression.
Now the PSS result for that signal will be plotted after next run.
Best Regards, Yawei
