Jul 17th, 2024, 11:31am
HSPICE stateye analyse (Read 5675 times)
haykp
Oct 28th, 2011, 12:24am
Dear Forum,
Please help me understand what does the HSPICE stateye analyze.
I am running stateye on some op amp and there are some parms which I cannot understand in that analyze, those are
1) port instance
2) incident and probe
Any book, article will be helpful.
Thansk,
Hayk
raja.cedt
Re: HSPICE stateye analyse
Reply #1 - Oct 28th, 2011, 1:46am
hello,
is stateye is for serial link simulations or any generic tool? because for SERDES i have used this, but you said for opamps.. how come?
Raj.
haykp
Reply #2 - Oct 28th, 2011, 5:04am
Hi Raj,
Frankly speaking don't know. I have found some example where stateye analyze is done on some Op-Amp circuit.
But if you are familiar with SerDes, then could you please help me understand what is stateye, how to run it and read eye diagrams.
( Like you perfectly explained me in the last time  :) )
Any book or article would be helpful.
Thanks in advance for you help.
raja.cedt
Reply #3 - Oct 28th, 2011, 5:26am
hello,
Please find the attached doc, which may be helpfull. But could you show me where did you find opamp with stateye.
Raj.
haykp
Reply #4 - Oct 28th, 2011, 5:44am
Dear Raj,
Thanks for the file.
Please see the attached screenshot, where is the test-bench of opAmp on which statetye is run.
haykp
Reply #5 - Oct 31st, 2011, 3:24am
Hi Raja,
Would you please point me some other, more simple, doc where I can read about stateye analyze.
Seems I need to gain more basics on this prior reading the attached doc.
Hayk
