Sep 12th, 2024, 12:20am
how the cmdmprobe works? (Read 6360 times)
NeilYu
Feb 29th, 2012, 7:12am
hi all,
I try to understand the cmdmprobe in analogLib by raturn ratio method.
But I have a question why the pcccs source is added in it.
Neil
Re: how the cmdmprobe works?
Reply #1 - Feb 29th, 2012, 5:02pm
Neil,
 Which version of MMSIM are using? From MMSIM 10.1(?),
a new component has been released and it is the
recommended element for differential stability analysis,
the diffstbprobe. The cmdmprobe is still supported for
backwards compatibility.
NeilYu
Reply #2 - Mar 1st, 2012, 7:08am
Hi  Sheldon,
Thank you very much for your comments.
I asked the question because I found that the DC loop phase is zero degree(180deg is reasonable). So I try to understand how the cmdmprobe works and I wonder why CADers add the pcccs. Due to the pcccs, the zero degree happens.
I just saw diffstbprobe in my version. But the details about diffstbprobe are not available. What's the difference between diffstbprobe and cmdmprobe?
Thank you very much & Best Regards
Neil
« Last Edit: Mar 2nd, 2012, 5:29am by NeilYu »
Frank Wiedmann
Munich, Germany
Reply #3 - Mar 1st, 2012, 7:40am
The diffstbprobe has the advantage that it also works correctly for non-symmetrical circuits. See http://sites.google.com/site/frankwiedmann/loopgain#TOC-Loop-Gain-of-Differentia... for some details.
