Jul 31st, 2024, 3:24pm
CMOS CCII using translinear loop (Read 4916 times)
varun
Apr 04th, 2012, 11:07am
hello everyone,
i m designing current controlled CMOS second generation current conveyor using translinear loop. I want to perform ac and dc analysis of the circuit . Can anybody tell me how to perform these analysis and how to get the current form the output terminal(z), i m using cadence spectre simulator for the simulation of this circuit at 0.18um technolgy.
i have also attached the circuit in this post
thanking u
Re: CMOS CCII using translinear loop
Reply #1 - Apr 5th, 2012, 2:43pm
Your question is very poorly posed.  I can't tell if you have no idea how to run a dc analysis in Spectre (because you're used to Spice3 or HSpice or something), or if you know how to run an analysis but you don't know how to save currents in Spectre, or if you have no idea how to turn the picture into a Spectre netlist.
Do you have a netlist?
varun
Reply #2 - Apr 7th, 2012, 2:45am
sir,
i know how to perform the analysis of the circuit but i find it difficult to get the diffrence of current from two series transistor M7 & M6(ie Z+) terminal by applying a current at X terminal.
i want to sweep the current at X terminal and get the same current at Z+terminal.
is it possible to design this circuit at single supply(ie Vdd and gnd)??
Reply #3 - Apr 9th, 2012, 5:15am
Varun,
  Is this the testbench you are using? How do you set the dc level at Z+?
achim.graupner
Reply #4 - Apr 10th, 2012, 3:27am
Hi
one more hint: CMOS translinear loops (exploiting the exponential V-I behavior) are very vulnerable to the mismatch of the threshold voltage (much more than when using bipolar devices).
May see my MIXDES'2000 paper "THE SWITCHED TRANSLINEAR PRINCIPLE
AND ITS APPLICATION"
regards
Achim
Achim Graupner
ZMD AG, Dresden, Silicon Saxony, Germany
varun
Reply #5 - Apr 10th, 2012, 10:54am
hello sir,
The main problem that i m facing in designing this circuit is how to set the W/L of the transistors constituting translinear loop. I want to put all transistors in  saturation region and earlier this circuit was simulated using BJT in which current follows exponential behaviour. So i want to know how to set the  w/l values of these transistors while keeping them in saturation.
i m designing this circuit in 0.18um UMC technology with vdd=+0.9v
and VSS=-0.9v with biasing current of 50u.
thanks
