Jul 17th, 2024, 5:31am
How to plot gmn+gmp in cadence using calculator? (Read 4948 times)
Larry_80
May 3rd, 2012, 5:57pm
So i am trying to plot gmn (transconductance of NMOS) + gmp (transconductance of PMOS) vs Vin. I was able to save gmn and gmp for eacd DC operating points, then i plot the result of gmn and gmp. But when i try to use the calculator to plot expression (gmn + gmp), the calculator seems unable to evaluate it. I am not sure if i am doing this correctly?
« Last Edit: May 03rd, 2012, 10:24pm by Larry_80 »
boe
Re: How to plot gmn+gmp in cadence using calculator?
Reply #1 - May 4th, 2012, 4:05am
Larry_80,
Did you use the same values for Vin?
- B O E
raja.cedt
Reply #2 - May 4th, 2012, 5:28am
hello,
sorry to ask you, can you please tell me how to plot gm in cadence (i can chech in the operating point but i would like to plot vs some variable )
raj.
Reply #3 - May 5th, 2012, 9:03am
Raja,
 Try opening the Results Browser, then selecting dcOpInfo
for the desired device select the dc operating point parameter
you would like and send it to the Calculator. Repeat for the
opposite polarity device.
Example:
Results Browser: dcOpInfo --> NM0 --> gm, see selectgm.tif
Also attached is an example of the plotting the sum of a pch and
nch gm, see plots.tif
Reply #4 - May 5th, 2012, 9:06am
Using the Results Browser
