Output noise in a spice(-like) simulator is generally computed as the noise voltage at a particular node, hence the units of V/rt Hz.
If you want A/rt Hz, then you need to have a simulator that supports current probes for noise analysis. Check the Eldo manual; I don't know if it does. And you also need a circuit architecture for which the noise current is relevant: if you haven't put on an appropriate load, you circuit won't be supplying current and you won't be able to measure the noise of a non-existent current.
