It appears that you are trying to measure a dc, low frequency, quantity. What was the minimum frequency you defined in your s-parameter file? Did you define a dc value? If the minimum frequency is 100MHz and you are trying to get a dc value then did you do anything to improve the dc value estimation, for example, set dcextrap? More/any detail about what you are doing would be helpful.
